Hey Morgan
Scottie-GNZ
That is what I have in the car right now. Problem is that I am running this new chip and when the RPMs drop below 4000 at WOT, the chip references a different table and retards the timing and leans the fuel out slightly. Unfortunately, because the GN is not a high revver and I have to shift to OD, the RPMs drop down to 3660 (.67:1 OD) and I end up losing a bit on the top end. Since I expect the car to go even faster, the situation will worsen.
I want to see if I can go through the traps in 3rd but do not want to run a 28" tire. The option is to go for a cam that raises the power curve and rev limit but might hurt the bottom end a little and the low-end torque is the strong point of this engine.
The GNs that have the same power as me do not have this problem because they run a 3.42 and their MPH is not as high.
Scottie
71 240GN-Z
Scottie's GNZ
[This message has been edited by Scottie-GNZ (edited February 02, 2001).]
