Guest Anonymous Posted January 27, 2001 Share Posted January 27, 2001 well, since my tranny is going out on my 79 280ZX i have decided to just put a new tranny in it. my big question now is what tranny will bolt right up and will handle about 250 hp/tq with no problems? the clutch will be changed out as well. i thought about getting it rebuilt, but i have gotten burned 3 times from local shops doing rebuilds on my previous vehicles. is there a reliable rebuilder in the D/FW area? Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted February 3, 2001 Share Posted February 3, 2001 any 75 up z trans will fit but best trans is a 82 or 83 non-turbo.most used trans will have counter shaft bearing problems.i build my z trannys myself.find a good stick trans shop and carry your trans in .if you get a used trans check drain plug-it has a magnet on it.if trans howls in evry gear except 4th it has bearing problems.leaks are usually at speedo drive-there are seals that should be replaced in the drive unit.trans is easy to work on if you have any manual trans experience. Quote Link to comment Share on other sites More sharing options...
