How much is an LSD that needs a rebuild worth?
Evan Purple240zt
Depends on what you mean by rebuild......
If it needs a new bearing, then it probably needs all new bearings. And the bearings are really expensive! If it needs clutches, each disc and plate is around $30, and there are what, 7 per wheel?
If you just mean oil seals, gasket, and a new breather then it's $30 or thereabouts. If it needs shims or to be re-setup it's not expensive either.
I have 2.5 LSDs now, 1.5 will be for sale once I put one in my car and ensure it is in great shape. One complete that is loose, and a 12mm 3.7 gearset, LSD assembly, and finned rear cover(scavenged from a LSD that blew the bearings).
Morgan
http://z31.com/~morgan/s30
http://carfiche.com
