Reground Stock P90a Cam - Rough Idle
ktm
My P90a cam was recently reground after an incident where a hydraulic lifter backed out and collapsed. I just installed the new cam and while the car purrs like a kitten from 1200 rpm on, it idles rough.
I was pulling a rock steady 18 in Hg vacuum at idle before the cam incident, now I pull 10 to 12 "shakey" in Hg at idle. However, at 1200 rpm I pull 18 in Hg.
No vacuum leaks that I could detect and the car pulls hard and strong through the RPM ranges. I pull 15 in Hg while cruising like normal and I'll go form 15 in. Hg to 12 psi boost in 500 rpm.
Still, my idle is rough.
I checked the lash on the rockers and as expected with a hydraulic cam, there is no lash.
Any thoughts?
Edit: I forgot to add that during a high RPM throttle lift, I'll pull 22-23 in Hg which is consistent with my old cam.
i dont know much but i did get my p90a cam ground with delta, now i am still working on my motor so i havent started it up. but on the box it says to use high rpm grease or something and when the car starts run the car at 1500-2000 rpms for 20 minutes to break the cam in. the only reason why i say this is because you didnt put that in your post, so that's why i decided to mention it. but if you did do this then i have no clue and sorry for wasting your time.
