R180 reassembly question- side flange alignment?
Mn_Z_Man
Getting ready to reassemble my 180 after cleaning, checking lash and new seals. I noticed 2 1/8" holes inside the hub where the side flange stub inserts, and 1 slight flat spot on the flange stub, just ahead of the splines. Should this flat spot line up with one of the holes for oil circulation to the spline area? FSM appears mute on the subject, and I didn't know to look when I took it apart. Can supply picture if I got my terms messed up.
thanks
E
