260z rb25 questions
jasonb
hey, im from australia and recently got myself a 260 2+2 from my grandad who has had it since new... lol.
wat i plan is a fairly decent rebuild including an rb25det
couple questions ive been searching but cant find...
1. with castelmaine rod shop mounts will the stock oil pan be ok or will it need to be replaced/modified? wats involved if so?
2.will the stock manifold and turbo clear in a low mount position?
3.any other issues with clearances/mounting items?
cheers would appreciate links 2 write ups if any1 knows any
cheers
Jason
cheers
Jason
Hey Jason,
Use the search function mate, as well as read all the stickys at the top of the RB forum, all your Q's will be answered plus many more you havnt thought of yet :wink:
I am using the CM Rod shop mounts, you will still need a rear sump oil pan (the stock RB25 one is front) Many of us here buy a new sump from Nissan from a JDM only Z31 300zx with a RB20 in it, which has rear sump, which will bolt on and work on RB25 and RB30. This sump can then be modified to increase oil capcity and baffles etc.
The part numbers of the new sump and oil pickup are else where on this forum - check the RB stickys.
