datman Posted May 5, 2008 Share Posted May 5, 2008 I just got my Greddy Profec A installed at it works a treat! I have seen some posts around saying there had been problems with this unit. I have a dual port actuator which I set the base pressure at 7 psi. I connected the controller to it as you would an external wastegate (dip sw1 set for external) I ran a vacuum hose from the manifold to the first port of the actuator (one nearest the front of the car) I ran the hose from the valve unit (port under the letter G of Greddy) to the other side of the actuator ( one nearest the wastegate lever). I connected the port from the valve unit (under the letter E of Greddy) to the boost port on the turbo and T'd the port on the valve unit ( under the letter Y ) into the hose that runs to my fuel pressure regulator (from the manifold). After doing 2 pulls in 3rd gear the unit was ready to use, I set the bost level at 7 psi and it held all the way to 6k, then tried 10 psi and then 14 and it was rock steady. Seems like a good little unit which can be picked up for a good price off ebay. like this but imagine the external is a dual port internal profec2.pdf Quote Link to comment Share on other sites More sharing options...
Guest brett1991sx Posted February 28, 2009 Share Posted February 28, 2009 ok i just bought my 1991 240sx i am interested in puting a turbo into it but keep the automatic transmission in for now do you know if that is possible and if it is what parts will i need to do so i have been racking my brain trying to figure this out any and all information you would have would be great thank you for your time Brett l. Ross Quote Link to comment Share on other sites More sharing options...
