ur2h Posted May 27, 2008 Share Posted May 27, 2008 I just recently bought a 77 280z. I'm contemplating with the research I have done so far(not much by the way, it's all kind of confusing and overwhelming) if I should keep my Z n/a or go boost. I want to make the engine strong but keep it reliable for street use as I will be using as a daily driver. As far as I can tell from what I've read, replacing the head for the MN47(most likely would get a mild port job and shave before install) would make the best numbers. My engine is EFI, should I convert to carb or is the fuel injection a better(reliable) setup? If I go boost, can I use my block and just change out the head to a P90(turbo head right? is this the best flowing head for a turbo setup?) and get the boost essentials, or do I have to do a complete engine swap? I want to keep my L series and will do research on a stroker setup after I have good enough knowledge to move on, but as for now it's one thing at a time. Any and all opinions on the subject matter will be highly appreciated. I'm a newb at this so I apologize for my ignorance on the subject, but I figure asking questions is the best way to find answers. especially since most of you out there "have been there and done that." I'm just on my way. Thanks. Quote Link to comment Share on other sites More sharing options...
Nigel Posted May 27, 2008 Share Posted May 27, 2008 Have you looked in the turbo/supercharger sub forum yet? Most of your turbo questions can likely be answered there. In fact, there's a sticky... http://forums.hybridz.org/showthread.php?t=84860 Nigel '73 240ZT Quote Link to comment Share on other sites More sharing options...
Challenger Posted May 27, 2008 Share Posted May 27, 2008 http://forums.hybridz.org/showthread.php?t=128905&highlight=500hp+l28et Heres a good one. Like Nigel said start reading through the turbo sub forum, along with the nissan 6 cyl sub forum. Do some searching, stay up till 2 in the morning for a few weeks and you might have an idea what you want to do. Quote Link to comment Share on other sites More sharing options...
JSM Posted May 27, 2008 Share Posted May 27, 2008 After all said and done, I would simply read this site for 1 year. Then come back and tell us what you are going to do. I've changed my mind so many times and have boat loads of cash tied up in parts currently. I think I would have still done it the same but it would have been much easier if I knew more going in. Make it run just the way it is and I mean 100%. Fix the old stuff. You'll have tons of questions anyway and learn alot. This won't make much sense to you now, but if you take the advise and do it, I swear it will in a year. Maybe take 2 years! Quote Link to comment Share on other sites More sharing options...
Challenger Posted May 27, 2008 Share Posted May 27, 2008 After all said and done, I would simply read this site for 1 year. Then come back and tell us what you are going to do. I've changed my mind so many times and have boat loads of cash tied up in parts currently. I think I would have still done it the same but it would have been much easier if I knew more going in. Make it run just the way it is and I mean 100%. Fix the old stuff. You'll have tons of questions anyway and learn alot. This won't make much sense to you now, but if you take the advise and do it, I swear it will in a year. Maybe take 2 years! That is very true, I went from 350, turbo L6, Lt1, turbo L6, na L6, turbo L6, 360, 318, turbo L6... That was in the last year or two. I finally made up my mind on the turbo L6 and bought myself an engine and have done my research accordingly. Quote Link to comment Share on other sites More sharing options...
ur2h Posted May 28, 2008 Author Share Posted May 28, 2008 okay, i think after the last two nights of contemplating which way i want to go, i think the optimal choice for me to pursue is to go boost. although the stroker looks the most unique and raw, seems like a long road if i venture that way. Quote Link to comment Share on other sites More sharing options...
ur2h Posted May 28, 2008 Author Share Posted May 28, 2008 I have a F54 block, how can I tell if I have the flat top or dish top pistons? Quote Link to comment Share on other sites More sharing options...
Challenger Posted May 29, 2008 Share Posted May 29, 2008 For my smart alec response, remove the head... or get a coat hanger, and stick it in the spark plug hole to feel for a edge on the piston. If you dont fell an edge its flat top, if you do dished. Quote Link to comment Share on other sites More sharing options...
ur2h Posted May 29, 2008 Author Share Posted May 29, 2008 thanks challenger, that seems easy enough. Those thread links help, thanks to those who provided them. but I'm at the moment just getting started and building a high performance L28 turbo is not in my current agenda. i want to just keep it simple for now... stock turbo application. edit- actually those threads covered everything i needed to know. thanks again!! Quote Link to comment Share on other sites More sharing options...
