Shaner Posted June 10, 2008 Share Posted June 10, 2008 Hi all, I've got a 74.5 260 with a '85 305 and am playing with the cooling system right now. Running a 3 core Z radiator. I had a homemade fan shroud( a sheet metal box around the radiator with a hole for the 14 in electric fan mounted on it) the box is about 2" deep and covers the radiator completely. I was overheating on the highway(up to 215-220) with a 160 thermostat in, but cooling fine in stop and go. Last weekend I removed the shroud and installed a 16 inch fan without a shroud. Took it out on the highway and temps stayed at 180-190 the whole way(75 degrees outside). But after running it and got off the highway the fan wouldn't cool down at idle(the temp would still go up at idle.) Okay, so I need to have a fan shroud. But it seems the one I'm running is restricting airflow at highway speed. Should I modify this one(trap door, louvers,etc) or should I start boxing in the front for better air flow to force the air through it all. Looking for any suggestions anyone might have!!!Thanks! Quote Link to comment Share on other sites More sharing options...
jaguargt Posted June 11, 2008 Share Posted June 11, 2008 Here i found something, it could help... http://forums.hybridz.org/showthread.php?t=129381&highlight=Shroud Greetings, Quote Link to comment Share on other sites More sharing options...
dustin280zx Posted June 11, 2008 Share Posted June 11, 2008 Here i found something, it could help... http://forums.hybridz.org/showthread.php?t=129381&highlight=Shroud Greetings, that's the radiator i bought from austin (thanks alot by the way). you can see pics of it under the "280zx turbo" thread Quote Link to comment Share on other sites More sharing options...
Shaner Posted June 12, 2008 Author Share Posted June 12, 2008 Thanks Jag, The other research I've been reading all points to the same thing. "quit screwing around and go get the right stuff" Thanks, Guys! Quote Link to comment Share on other sites More sharing options...
