ktm Posted June 28, 2008 Share Posted June 28, 2008 Is this the self-adjusting component of the slave cylinder? What is the purpose behind the internal spring? If you have an adjustable slave rod with an external spring, can the internal spring be removed? Finally, if the spring pre-loads the T/O bearing against the PP fingers, is this not a "bad" thing? Thanks. Quote Link to comment Share on other sites More sharing options...
