Chartoo Posted July 11, 2008 Share Posted July 11, 2008 I got a pair of lowered springs of a mate but he cant remember if they are front or rears. Is there a way to tell the difference or is there any difference? Cheers Quote Link to comment Share on other sites More sharing options...
Trevor Posted July 11, 2008 Share Posted July 11, 2008 Stock parts: Fronts are 16in and the rears are about 15.5in. long. Rate for fronts 100lb./in. rears 125lb./in. Tokico lowering springs: Fronts are 11.5" long vs.11 1/8" for the rear. Rate depends on # coils, wire diameter, etc.... Have a hydraulic press and a bathroom scale? squeeze the mystery spring in a press, on top of a bathroom scale. Preload about 1 inch(25.4mm) , record how many pounds (or Kgs). The carefully measure while you squeeze it down 1 more inch, subtract the 1st weight from the 2nd to determine the spring's static working rate in lb./in. Quote Link to comment Share on other sites More sharing options...
Chartoo Posted July 13, 2008 Author Share Posted July 13, 2008 Thats good. Is there a way i can find out if they are designed to be front springs or rears. Are they different thicknesses or just different heights and spring rates? Quote Link to comment Share on other sites More sharing options...
