Question about speedometer gears
cholag
I have a 1983 ZXT that had a auto trans, but I found a t5 in the junk yard, so I had pulled that and now I am rebuilding it. But I was wondering, to make the speedometer work do I need the speedometer gear out of my auto trans, or will the speedometer gear in the t5 work with my existing speedometer cable?
you're only changing the TRANSMISSION, which is a totally different part from the DIFFERENTIAL. the speedo gear is only dependent on which rear end you're using. not the transmission.
oh, also r180/r200 doesn't matter. only the actual gear ratios inside (that is, if you're changing your diff as well as your transmission)
