Guest chevsun Posted November 28, 2001 Share Posted November 28, 2001 while I have the back of the car apart for all the coilover, bushing, cv upgrades I need some input on what might be making my 3:90 200mm howl at highway speeds with no load. It resonates pretty loudly inside and I would like to fix it now if I can find what's causing it(I have changed the oil). I had no insulating material in the car except carpet but will be adding sound proofing this winter. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 28, 2001 Share Posted November 28, 2001 Maybe it's lonley. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 29, 2001 Share Posted November 29, 2001 I'll have a guess, pinion bearing might be worn causing the pinion to ride in a different location on the ring gear and the strange contact pattern might be causing a whine (howl). Or.... The bearings supporting your ring gear are worn. Just a couple of idea's of what sometimes causes rear ends to make noise. Regards, Lone Quote Link to comment Share on other sites More sharing options...
Guest chevsun Posted December 3, 2001 Share Posted December 3, 2001 Got the 200 on the bench today and pulled the cover. I can't really see any problem. I checked the pattern with High spot blue and it looks good. The only question I have is on the backlash for an 83zx 2+2 R200. The only service manual I have is for a 73-240 but the recommended backlash for the 180 is .0039 to .0079. I have .007 and would just like to have verified that it is an acceptable # for the 200. Does anyone have a book that can help me out on that? Maybe the soundproofing I'm doing this winter will keep the noise out. I think I read somewhere that the 200's made more nois that the 180's but the superior sound proofing on the newer vehicles made it unnoticable. Am I dreaming here or what. Quote Link to comment Share on other sites More sharing options...
