Guest 400 ci 280z Posted December 2, 2001 Share Posted December 2, 2001 i am doing a engine swap and was wondering if the r200 can handle the power made by a stock pontiac 400ci engine. thanks for any help Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted December 2, 2001 Share Posted December 2, 2001 Yes you shouldnt have a problem. The 200 rearend is being used by many here including myself. But like anything if you abuse it enough it will die. zfan...Mike Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted December 2, 2001 Share Posted December 2, 2001 hey thanks for the info Quote Link to comment Share on other sites More sharing options...
Guest 400 ci 280z Posted December 2, 2001 Share Posted December 2, 2001 i am going with an auto trans. but when i get it done i will post a couple pics. Quote Link to comment Share on other sites More sharing options...
Guest Tom Scala Posted December 3, 2001 Share Posted December 3, 2001 Being a long time Pontiac guy I'd like to see a picture of that. Are you using the Edelbrock Aluminum heads or stock iron? Just remember the Pontiac engine is a torquer and will make more low end torque than a 400SBC. 450+ ft lbs is easy to get and you'll have it by 3500-4000rpm. The R200 is strong but shock loading with a stick trans and Pontiac torque would make it very marginal. If you use an auto and don't run slicks you should be ok. Quote Link to comment Share on other sites More sharing options...
