bigjohnsonzc Posted August 16, 2008 Share Posted August 16, 2008 K i have lots of questions here im starting a new project and have been doing lots of reading but some of the things i have found are very contridictive... What rear end do i most likley have. its a 77 280z 2+2 fairlady... from japan. i have noticed that the number on the cylinder head and even the block are different numbers then normal so im assuming i have the same thing gogin on with everything else in this car. . . im thinkin the R200. I know i prob could check and see what the numbers have to say... ill check this weekend and post them up and see what i find out and then i prob can get a better answer for sure. im looking to strok the 2.8L to the 3.1 if i can so i think the R200 rear end would be better.. let me know what you think Thanks Z Johnson Quote Link to comment Share on other sites More sharing options...
Stealth-Z Posted August 16, 2008 Share Posted August 16, 2008 Most likely you have a R180. Do not toss it until you pull the cover and check the gear ratio. Both mine had 4:11's. Quote Link to comment Share on other sites More sharing options...
bigjohnsonzc Posted August 17, 2008 Author Share Posted August 17, 2008 here is a picture of what i got ..... Quote Link to comment Share on other sites More sharing options...
Stealth-Z Posted August 17, 2008 Share Posted August 17, 2008 R180. Same setup that was in my 76 and 78. Quote Link to comment Share on other sites More sharing options...
