Guest Anonymous Posted December 28, 2001 Share Posted December 28, 2001 I was wondering if there were any other rear ends that could swap out with the one in my early 260 beside the 200 from later z's. If there isnt, would gears for any other rear end fit, eg. ford 9 inch? Thanx Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 28, 2001 Share Posted December 28, 2001 R230 MAY fit - that swap is being worked on. 9inch gears will NOT swap in. What's your goalpoint here? What ratio are you trying to get and why? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 28, 2001 Share Posted December 28, 2001 I didnt literally mean 9 inch gears, it wasjust an example. Ive heard stories about people blowing their rear ends out, so I started thinking that if i could get gears made for a more popular rear end, like a 9 inch ford. I knew they wouldnt fit, but are there any other popular rear end gears that would? Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted December 29, 2001 Share Posted December 29, 2001 Gears don't blow generally - it's usually something else that goes first. There are pins in the rear, Ujoints, and some other weak points but for the most part the gears in th erear are fine so long as you've upgraded ot an R200. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 3, 2002 Share Posted January 3, 2002 Sounds good. thanx Quote Link to comment Share on other sites More sharing options...
