Flexicoker Posted October 5, 2008 Share Posted October 5, 2008 Hey guys, megatune had been working flawlessly for a few weeks, I was able to take hour-long logs on my way to work and back, but now it won't run for more than a few minutes at a time before freezing. I tried Tunerstudio and the same thing is happening. I'm able to unplug the USB cable (serial-USB converter from DIY) and everything unfreezes, and I can usually plug it back in and it will work for a few more minutes. Any ideas? this is really frustrating. To my knowledge, nothing has changed from when it worked right, and everything is set to the same COM # and baud rate. I tried lowering the data rate with no success. Thanks -Eric Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted October 6, 2008 Share Posted October 6, 2008 How exactly is the USB cable set up? I have seen one weird case where attaching the USB adapter to the Megasquirt directly had issues with EMI from the Megasquirt and made the adapter flake out - putting a straight through DB9 cable between the adapter and MS fixed this. More commonly, I've seen the USB adapter plugged in without its extension causing the adapter to wiggle around in the socket and come unplugged briefly, which also causes the tuning program to freeze. Quote Link to comment Share on other sites More sharing options...
Flexicoker Posted October 6, 2008 Author Share Posted October 6, 2008 I doubt its the USB end... its tight in there. I will try using a straight through DB9 to move the adapter away, it does seem to freeze more often when I'm at higher RPM's... but i could be imagining it. Thanks! Quote Link to comment Share on other sites More sharing options...
Flexicoker Posted October 10, 2008 Author Share Posted October 10, 2008 SUCCESS!! I finally got around to buying a DB-9 to put in between the megasquirt and the USB adapter, and it worked flawlessly. Thanks Matt! Quote Link to comment Share on other sites More sharing options...
