Guest triple_threat311 Posted March 15, 2002 Share Posted March 15, 2002 I need a little assistance on the CV swap. I have CV halfshafts from a 81 280zx Turbo, the and the kit from Ross. The adapters are installed on the car and the locknut is torqued to 200ft/lbs. I popped out the two flanges where the old U-joints used to fit, and the halfshafts slide in. But I can't compress the shaft far enough to fit into the adapter. I compressed the shock to give myself a little bit more clearance, but It still needs just a little bit more to slide in. Is there a better way to install these? Do I have the correct halfshafts? I also pulled the cover off the differential and drained the gear oil out. But I am not able to get the fill hole open. So since I have my halfshafts out, I put in a little bit over a quart in. But I am not sure exactly how much gear oil should be added. the POS haynes manual I have said I needed to put in 1 Liter, but I am not sure if that is for a R180 or r200. I have a r200. Thanks for all your help anthony Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted March 16, 2002 Share Posted March 16, 2002 I'll let others reply on the shaft install (as they've done it more recently) but as for fluid volume, I've always put about 1-1/4 litres or so in mine (one US quart is 0.95 litres). On a similar note just in case...to date 2 - 240Z owners found some interference with their stubnut and CV shaft end cap which one resolved by sectioning/shortening his end cap by ~1/4" and shortening his inner CV spring slightly to match. Neither Scottie nor I know what combo led to that interference as he's not heard of it from anyone else and neither have I till just recently. Just a possibility that has arisen but first you'd need to have your CV endcap into the adaptor to discover that. Quote Link to comment Share on other sites More sharing options...
