cobra maf vg30e
BlueZ31
as a supporting mod for the 60mm tb/engloids plenum/ cams ive got ready to install im considering also using a 94 cobra maf, BUT it seems that i cant find a clear answer on using one. Some posts/ other nissan forums state that its a simple swap and you dont need any tuning or changes to the ecu to use it, while others state that you absolutely need to reprogramm the ecu to function at all with the larger maf, which is right?
Im sure that tuning would reap the full benifits of the larger maf but is it as simple as plug and play or is it necessary to change over to a jwt ecu or likewise? ive already got a maf lined up at a local salvage yard, i just need a clear answer, and also, why the cobra maf? why not just a 5.0 'stang or truck maf or is there a difference between them?
thnx, hope you guys can help!
