getZ Posted October 10, 2008 Share Posted October 10, 2008 Anybody have any baseline tuning info for edlebrock pro-flo 3500? I pulled the whole thing off my camaro and put it on the z car to make use of it and keep the unit running. My combination is a 383 with dart 200cc heads at about 10:1 compression. The cam is a single pattern cam 238 @.05 with 480 lift. The orignal chip was burned for the edelbrock performer rpm combo, heads and cam (edlebrock performer rpm heads are 170cc intakes and cam is 238/248 @ .05 and the lift is 488/510. I'm new to tuning fuel injection and the books I have aren't that helpful. It looks like a lot trial and error under different conditions to get it right. I thought it would be as simple as just hooking a wideband O2 sensor on it, tune at various rpm levels and away you go. It turns out the engine fuel needs are very different under load and temperature. There's even a provision for quick pedal movement to compensate. I plan on starting conservative with timing and fat on fuel, but that seems easier said than done. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted October 10, 2008 Share Posted October 10, 2008 The pro-flo is made to run with certain cams. The best thing to do is call the Edelbrock tech line and tell them what you have. They can burn a new chip. http://www.edelbrock.com/tech/ Quote Link to comment Share on other sites More sharing options...
getZ Posted October 10, 2008 Author Share Posted October 10, 2008 That's probably what I will land up doing. The first time I called them, they said I could tune it by hand if I was computer savy, so I thought I would give it a try. I don't think it's incredibly difficult, but you need two people to do it. Sombody watching the controller with the wideband and the other guy driving. I tried doing it by myself and it's extremely hard to read an LCD display while driving. Quote Link to comment Share on other sites More sharing options...
