Guest 1fastz Posted March 29, 2002 Share Posted March 29, 2002 Just a question as i havent scored my r230 yet but i see thebraces you guys are useing.. ? WHY not kill two birds at once and for a rear mount and to keep the side suports for the controll arms strong .. simply weld a 5 inch wide steel plate between the two drop pieces that go down to the rear controll arms .. then drill that piece with the two holes for the rear mount of the dif cover bolts.. that way you have a solid mount in the rear for the dif no more mustach bar bushings and you have also shored up the controll arm ataching bars. Quote Link to comment Share on other sites More sharing options...
