Guest Frank280z Posted March 27, 2002 Share Posted March 27, 2002 Got a great deal on a t5 from an 86 gt. My brother went with tremec tko. Pete I know you did this setup. What am I exactly getting into.$$ So far I know I have to change the pilot bushing and clutch disc. What do I do about the bellhousing? I guess I will be selling the M21 shortly after this. What are these things worth? Thanks for any input. Frank Quote Link to comment Share on other sites More sharing options...
Guest Thurem Posted March 28, 2002 Share Posted March 28, 2002 Hey I have expounded, a few times on this subject, cause I'm doing the same thing. I replaced my main case with a chevy case, brandnew from 5speeds.com for 45$(price may have changed). I also got their 5'th gear stabilizer, which is a billet steel bearing retainer for the countershaft, 60$ app.. You will also need an input bearing retainer,in steel, from the same place for about 21 $, this is the same piece the throwoutbearing rides on. If your trans has a 2.95 ratio first gear you can replace the input shaft with a chevy unit, otherwise you need to get yours shortened. By the way mine is still apart until I figure the gearing in my rearend, so I can install the correct speedo gear while it is apart. email me for questions. Later Thure Quote Link to comment Share on other sites More sharing options...
Guest Frank280z Posted March 28, 2002 Share Posted March 28, 2002 Thanks for the info. Did a search...Looks like a bit more involvement than I wanted. I would like to just change my clutch disc and change the slave unit. Guess I'll keep looking for a GM unit. Frank Quote Link to comment Share on other sites More sharing options...
Guest Thurem Posted March 29, 2002 Share Posted March 29, 2002 Not really all that hard. Hardest part was pressing off a bearing that wouldn't clear the case when taking out the counter shaft. Just get a manual for the T5. Thure Quote Link to comment Share on other sites More sharing options...
