280zxt axle conversion
Blown77Z
How did you spell "Axle" in your search? You spelled it wrong in both your title and the verbiage of your post.
I only noticed because I tried to look for it and your post didn't even come up.
Not trying to make you look bad, just trying to help. :)
–noun Figure Skating. a jump performed by a skater leaping from the front outer edge of one skate into the air to make 11/2rotations of the body and landing on the back outer edge of the other skate.
ax·le
–noun 1.Machinery. the pin, bar, shaft, or the like, on which or by means of which a wheel or pair of wheels rotates. 2.the spindle at either end of an axletree. 3.an axletree.
JSM, I did spell it wrong, wow...:oops:
fastzcars, that's the one I was looking for, thanks !
StreetGlide07, if you decide to go the V8 route, this is the place to do it ! Shoot me a PM if you have any LS1 questions in the future.
Thanks guys for pointing me in the right direction :icon6:
Not sure if it is on this site, found over at zhome.com: Terry Oxendale wrote this:
Datsun CV joints
Before I had finished the final assembly of the above mentioned VW parts, I had noticed at the local salvage yard, that a 1982 280ZX Turbo had CV jointed half shafts (these are the same as some of the '84-'89 300ZX non-turbo half shafts* except they are 1 inch shorter). Upon further investigation I found that the ZX Turbo half shafts with the wheel bearing companion flanges where the same length as the Z half shafts with their wheel bearing companion flanges. Also, the axle stubs on my Z shafts had the same spline dimensions as that of the ZX half shaft splines. To make a long story short, I found that the entire ZX Turbo shaft assembly from differential to and including the wheel bearing companion flange that slips over the splines at the wheel axle can be interchanged with the same Z parts. It is the proverbial "bolt on" modification, with the exception of the inner grease seal area at each wheel bearing. The Z grease seal has a slightly larger ID (41mm vs. 40mm for the ZX seal) and OD (65mm vs. 73mm for the ZX seal), than the ZX grease seal dimensions, thus they cannot be interchanged and the swap will have an incorrect seal contact, unless you either use a thin sleeve slipped onto the ZX wheel bearing companion flange where the seal makes contact and in effect enlarging the outside diameter of the sealing surface (something similar to a "speedy sleeve") for the Z seal, or install a bushing into the wheel bearing carrier to allow the use of the ZX seal.
I chose to fabricate a bushing to be placed into the Z wheel bearing housing, and then place the ZX grease seal inside this bushing. This bushing was made by cutting 3/8" thick rings off of a section of 2-1/2" schedule 40 steel pipe. The outside diameter of these rings is a tad bit to large to fit into the Z wheel bearing carrier, so I split the rings at a single location by cutting out a piece of the ring. Then I compressed the ring evenly all the way around its circumference to close up the gap, that I had previously cut in it, to about 1/16", thus reducing the overall O.D. of this ring (bushing). Then I lightly chamfered the circumference of the ring. The ring can now be lightly pressed into the wheel bearing housing, into the location where the original Z grease seal used to be, thus closing the gap in the ring completely as the ring (bushing) is "squeezed" into the wheel bearing carrier (this is why I chamfered the rings, so as to allow them to be started easily into the housing). I found out through trial-and-error that the best way to install the grease seal into this bushing, is to first place the seal into the bushing before you press the bushing into the housing. This way the ring will compress around the seal, thus providing a good strong hold on the seal. I also used a small amount of gasket sealer at the ring gap and the outer circumference of the ring to seal the bearings completely from any dust and dirt.
The complete Turbo half shaft assembly in the installed position will be the same length as the stock Z half shaft, BUT un-installed, the Turbo shaft appears to be too long. This is because the casing holding the CV joints are spring loaded at the wheel end, making the shaft appear to be longer than the installed length will be. As you will see, the spring is fairly soft and can be totally compressed by hand to fit correctly, and still allow the shaft about 1/2" of play for suspension movement installed. To install this Turbo half shaft, you will need to temporarily increase the spread between the differential and the strut by (my method) removing the inner lower arm bushing saddles, thus allowing the strut (and attached lower arm assembly) to swing away from the differential. This procedure of spreading the strut away from the differential is needed because even with the shaft fully compressed, there is a convex knob (inside of which holds the spring for the CV joint) on the end of the shaft that fits into the concave companion flange already installed on the axle stub. In order to slip the shaft end into the companion flange you will thus need to gain about an inch extra clearance. Once the wheel end of the shaft is fitted into the companion flange, then the strut can be returned to it's normal position.
Note: In the time since the above information was written, another method of grease seal placement has been found which may be more appealing to the average builder. The R200 differential front pinion grease seal (75mm O.D. X 40mm I.D.) can be made to fit into the wheel bearing housing where the original grease seal fits in the rear struts, thus eliminating the need to manufacture the bushing using a metal pipe ring as discribed above. This new seal must have all the rubber removed from the outer circumference in order to reduce the O.D. to its minimum (about 73mm). Even with this outer layer of rubber removed, there will be an abnormally large interference fit which will make it difficult to install. I then chamfered the outer edge of the metal lip of the seal to facilitate it's installation, which was done by carefully tapping the seal into the strut bearing carrier with a large flat doughnut shaped plate used as a mandrel to allow even pressure to be applied to the entire seal as it is tapped or pressed into the carrier (be sure to use a small amount of sealant such as silicone to make this a water tight seal). One might even be able to use the axle stub threads and nut to press (draw down) the seal into the carrier with an appropriate shaped plate. Anyway, this pinion seal will simplify the grease seal problem by eliminating the need for manufacturing the metal bushing out of the pipe ring mentioned earlier to hold the ZX seal.
Also, the small dust shield that is pressed onto the ZX companion flange piece to keep dust and dirt away from the grease seal was swapped with the dust shield from the comparable Z piece. This was done to maintain a better shield due to the different designs. I did this by cutting the tack welds on the Z piece, I then pressed the shield off. Then, after I pressed the dust shield off the ZX piece, I placed it onto the Z piece and then permanently tack welded it on .
I wished I had found this swap prior to all the work and expense of the previously mentioned VW parts swap, but I still feel the VW setup is ultimately the strongest of the two. But for now, I will use the Datsun CV setup and see if it will hold up to the rigors of racing. The ZX swap cost me about $100 verses the $400 for the VW swap (thats in salvage dollars).
Note: when removing the wheel bearing retaining nut off the Z cars (to remove the wheel bearing companion flange), the threads on the axles will be damaged if the nut is not removed with care, due to the peening that is done to the nut to prevent it from working loose. Fortunately, this same nut on the ZX cars is just a regular lock nut (same threads as on the Z too), BUT, bring some help to break it loose. After using an impact wrench and then a drive ratchet with no luck, I finally had to use a "come-along" attached from the breaker bar handle to the car chassis to finally break it loose.
Important note: I recieved some feedback from a gentleman in Detroit that was performing this modification on a 260Z. It seems that his axle stubs in the 260Z struts were 26 spline stubs (whereas the my 240 axle stubs are 25 spline) with a slightly larger diameter that the 240 stubs. Thus the ZX companion flange would not slide on (This was double and triple checked and later compared to the 240 stubs and verified). Make certain you obtain the 25 spine axle stubs in the struts, or this modification will not work (In other words, make sure the Turbo companion flanges will slide onto the splines of the axles you will be using!).
*There are some important differences in the CV jointed half shafts for the 280ZX and the 300ZX. I will briefly list them so that replacement parts or salvaged parts might be found easier. From the data found in a CV joint rebuild guide that I was able to look through, I found that all the '82-'83 280ZX Turbo's and some of the 2+2's use the same exact half shaft. These half shafts use a "tripode" design in the CV joints, meaning they have a 3 pronged (120 degree), needle bearing equipped joint. The axles themselves are 14-11/16" long, both left and right sides, and have 27 tooth splines at both ends. All other 280ZX's use the U-joint type of half shafts. The differential axle stub assembled as part of the shaft has 25 teeth in the splines that will fit into the R200 "Z" differential.
