Mustache Bar stud replacement.
will c
Hello I got another z and that the previous owner was gonna set up with a solid rear axle but sold it half project. I however want to go with an r230 rear end. The problem I have is that he cut the studs that hold the mustache bar flush with the frame. How do these come out so I can put new ones in? do they unscrew?
thanks, will
thanks, will
If I remember correctly, the bolts for the mustache bar bolt in from the top next to the rear strut tower. You will have to remove your original vinyl (if you haven't already) to get to the bolt heads.
