R200 Diff Cap Torque Specs
Jon.. if you mean the (R 200) rear differential mounting member installation (2) nuts to differential rear cover it is: 54 to 69 foot pounds or 7.5 to 9.5 kg-m. If you mean the rear diff cover plate nuts... I do not believe there is any precise tightening specifications.
You are on the inside? What are you doing in there! drive pinion nut: 137 to 159....ring gear bolt: 43 to 51.....Side bearing cap bolt: 65 to 72..... Rear cover fixing bolt: 12 to 17..... Rear cover to rear mounting member lock nut: 54 to 69.... Diff carrier to front mounting Insulator fixing bolt: 43 to 48.....Companion flange to propeller shaft fixing bolt: 25 to 33.... Side flange to drive shaft fixing nut: 36 to 43......Drain plug: 30 to 50
