fuel pump and filter for surge tank? what to use?
hi
my goal
400whp
engine: 7mgte
use: street driving and a little back road drag racing.
after alot of reading and thinking i decided that the best and budget allowed way to solve my problem is just adding a surge tank in my 74 260z.
my set up will be based on this http://forums.hybridz.org/showthread.php?t=122978&highlight=surge+tank
i want to double check this.
--with this set up i wont need any modification on the tank right?
--can i use any carb filter for the feeder pump? any cheap ones out there?
--and second ive read that the stock z pump will be enough to feed the high pressure pump. is there other cheap fuel pump that can be used as a feeder? i dont want to use my super old pump.
--i will be using a walbro inline fuel pump as my high pressure.
--any body used a stock supra fuel filter? i have had supra thats rated around 450whp and used the STOCK filter and never had any problem. but supras are in tank pump. would it matter if it in line?
