turbeau Posted December 14, 2008 Share Posted December 14, 2008 just put the L28 in my 71Z and it wont start. i have full charge on battery, SUs, mostly stock. when i tried to start it the first time it ran for about 2 seconds then shut off. now when i turn the key the starter just clicks. i thought it was a fuel problem but there is fuel in the lines. i tapped in a fuel gauge next to #1 SU and tried to start it but the gauge did not move. when i checked the line there was fuel in it. i put the L24 distributor on it but still have the one from the L28. i didnt know how to wire the coil to the plug outlet on the side of that dist. any suggestions? check fuel again? check spark? thanks for any help Quote Link to comment Share on other sites More sharing options...
turbeau Posted December 14, 2008 Author Share Posted December 14, 2008 I got it started now it idles really high. around 2400-3600. i have loosened all the screws on the throttle linkage that might hold the gas open and have loosened the choke cables all the way. i moved the distributor to try and change the timing but still at 2400 at the second mark of the R. what is going on? Quote Link to comment Share on other sites More sharing options...
