700r trans problems,1991 suburban
Guest brianluckysoon
Sat for a year and then would neutral out for a few seconds shifting from 2nd to 3rd.
Drove it like this for about 20 times.Always shifted in 1st and reverse until now.Fired it up to get some wood in the backyard and moved around the wood pile back and forth a coulple of times and shut it of to cut wood.
Started it up and put it in reverse and backed up about 20 feet and the trans started slipping and then neutraled out.Put it in drive and moved forward and then reverse,reverse is like neutral and after about four trys I lost forward too, seeming like neutral.
I let it sit four a couple of hours and tryed again.No reverse but I had 1st about 4 times and then nothing.Tried again later with no reverse and selected low 1 and lost forward movement in about 2 seconds.
Fluid is at level,trans is quiet.
Im on unemployment and heat my house with wood.I just need 1st and reverse to get around the yard!Please Help!
