maybemark Posted January 17, 2009 Share Posted January 17, 2009 I have an 82 280zx turbo, that i put a megasquirt extra1 v3 board in. I decided to go with a Bosch 3 wire idle control valve. I picked up the mod kit, and wired as said. I seem to be having problem with getting the correct settings. The bosch valve is a 0280 140 505. Does anyone know the correct setting to install on the megasquirt, so this will run properly? I already have both the diaode connected and that huge 50watt resistor to ground. I think all I need now, is the proper settings. If someone out there knows, I sure would appreciate it. Thanks Mark Quote Link to comment Share on other sites More sharing options...
