swapping an early 280z tank into my 240z
My 240 tank has three breather lines, one on the rear side, one on the front, and one on the driver side. While the 280 tank has two on the rear side. Im assuming the larger one on the rear side of both tanks is the same but Im not sure where the line that went to the driver side on the 240 goes on the 280 and that also leaves that 3rd line.
Anyone whos done this swap know which vent lines go where?
and what did you do about the different sized fuel lines?
Im still using the stock fuel pump and running an L26 with 4 screw round tops until the L28et goes in sometime in the next month or two.
