Guest Anonymous Posted June 6, 2002 Share Posted June 6, 2002 What kind of a dollar amount are you suggesting? My budget it swiftly dropping and I have yet an answer to my problem. The driveshaft you are suggesting would consist of a yoke to match the T5, 2 u's from chevy and a flange to match the R200 (assuming the flange is the same on the diff. as the driveshaft). How would that be cheaper then swapping out the center section with a ford or chev. u's and keeping the datsun ends for the diff. and trans (that I know will fit)? The guy I spoke to can build me an entire shaft for $225 (ball park). Would the design you speak of reflect that price amount or would it differ? That is a great idea , I'm wondering if someone would have a used component lying around so I would not have to spend so much. Or mabye, I should wait til' I have more money (if ever ) and go with the custom setup. Nic Quote Link to comment Share on other sites More sharing options...
Guest Craig280z Posted June 7, 2002 Share Posted June 7, 2002 Driveshaft adapter flange from JTR is Drive Shaft Adapter Flange (2.25 Inch Pilot), #DAT-110 $49. Used driveshaft from junk yard from a car with the T5 transmission is? Cost from driveshaft shop to shorten the driveshaft to your required length is? That's all I got Craig Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 24, 2002 Share Posted September 24, 2002 Hey All, I just got finished replacing the driveshaft U-joints in an 83 280zx. Even though the Chilton's said it couldn't be done. I think I paid $28.00 for each end at a parts house in Houston (Houston Driveshaft 713-675-6375; ask for Kevin) The kit contains the cross (with zerks) and internal snaps to keep it all together. It is a pain in the ass but can be done. Maybe Kevin can come up with solid joints for the application. Best of Days hhaudio Quote Link to comment Share on other sites More sharing options...
Guest silverbullet Posted September 24, 2002 Share Posted September 24, 2002 I know that on my 77-280 you can replace the halfshaft U-joints because I have replaced them all already and they were in stock down at the local parts store(not the best quality though) but Craig280z is right you should be able to get a good shop to replace the U-joints with replaceables, MSA does or at least used to sell spicer "heavy duty" U-joints(don't know how strong they really are) for these drive shafts but I aslo agree with Craig280z again in that you should be able to have a good shop make you a stronger solution for not to much more I would think, good luck . Quote Link to comment Share on other sites More sharing options...
