Diff./ half shaft question
Guest zfan
I just scored a 3.70 LSD off a 300 ZX Turbo. I have a 1971 240Z with a 3.54 200r rear end. The half shafts are off a 78 280Z.
I want to possibly go with CV's, how hard is the swap to CV's? One of the CV's is damaged, drivers side so I will pick up replacement if need be.
If I stay with the old spicer half shafts what do I need to do? Reason I ask is the LSD has shafts removed leaving holes on either side of the diff, do I remove inner shafts from the old 200 and insert in new diff and just bolt on my half shafts to the LSD rear?
Hope this makes some sense!
Mike
Mike , I may be wrong but usually the 240 Z stub axle splines are the same as the CV splines making an easy bolt in. If I remember MadManAdam did this swap a few months back. Ross C has an adapter to mate the CV axles to 280 stub axles
