rb20det speedo cable
scottyMIz
  • 1 month later...
sanded down the white part of the back of the speedo so the 200sx cable will screw on. Also i had to cut a little off the end of the outsideof the cable that goes in to the speedo. The center kept workin its way back inside the cable so i just used a pipe cutter to cut about 1/2 inch off then reflared it with a pair of needle nose pliers.
