nicolemcgrgr50 Posted February 18, 2009 Share Posted February 18, 2009 Hello, I have a 71 240 Z I have pulled out the engine and now am putting it back in. I have the crank mark pointing up, The cam sprocket has a 1, 2, 3, on the outer ring 1 am pointing the 1 up also when i put it on the valver are hitting the piston. Does the position of the marks sound correct< both up?> AND i had to have the head milled due to it was leaking out the sides. This could be it but wanted to make sure i was installing the timing chain right?? Thanks for helping Quote Link to comment Share on other sites More sharing options...
Administrators BRAAP Posted February 18, 2009 Administrators Share Posted February 18, 2009 First and fore most, go get yourself a Haynes manual. Read it. This forum is a highly technical, performance oriented Z car forum, and is NOT a replacement for a service manual. Once you get to the point the service manual is of no help, or you need help in understanding the service/Haynes manual, we will be glad to help out. The Haynes manual will explain in detail exactly how the cam timing gear is to be installed. If I interpreted whatever it was that you were trying to describe, it sounds as though your set up is currently wrong and if you haven’t bent a valve yet, you will! I also changed your thread title, as covered in the PM. Good luck Paul Quote Link to comment Share on other sites More sharing options...
