silicone boy Posted November 13, 2002 Share Posted November 13, 2002 Well, there's been a lot of talk over the years about how stupid the T56 clutch slave cylinder is--it has no bleeder, it is made out of plastic, and it uses a stupid non-AN hose fitting (custom GM stuff). JTR, Mike Kelly have advocated tapping the plastic and using a 1/8th to -3AN coupler. I did this at first, but I couldn't leave well enough alone. I'm waiting for some parts (e.g. the Comp Cams hydraulic roller lifters that have been backordered for about a year ) and my brain was therefore idle, with nothing else to do, a dangerous situation. I used the spare time to work on the slave problem once and for all. A lot of people have talked about the similarity between the T5 slave and the T56. In fact, the picture in one of the JTR is a T5 with a tapped fitting, even though it says it's a T56. It is almost identical with the exception that it has a bleeder valve. Cool. For those of you that are worried about the plastic thing, forget it. It's pretty much indestructible (I should know, my wife accidentally drove over it when I left in in the driveway . Rather than tapping the plastic, I took a cue from Blkmgk (he used a T56 slave) and used the stock end fitting-or actually, I used the end that goes into the master cylinder since it is a straight, rather than angled one. After all, that's what came with it and is least likely to leak. I cut the tubing a few inches above this with my Sawzall (overkill, but it was within arms length of my computer when I saw Blkmgk's posting on the board from a few months back. I intended to get some pretty hydraulic fittings for the other end, but somehow it didn't work out that way. I was wandering around Home Depot with the slave in my pocket (don't ask me why, I don't know), when I came across their plumbing fittings. They're brass, not anodized aluminum, so I'll probably lose some horsepower, but I stuck a 3/16th barbed to 1/4 in adaptor into the free end. For those of you who are wondering if this by itself is secure enough, I can assure you that it is because it got stuck and I couldn't get it off-I had to assure the HD people that I wasn't trying to steal it. I then put on a 1/4 to 1/8 reducer followed by a 1/8 NPT to -3AN coupler (the last one is not a Home Depot part--I'm sure you knew that, but it's amazing how much quasi automotive stuff you can find a Home Depot, such as Ram Air stuff in the ventilation section. I wonder if you can find LSD's in the lawn tractor department--those riding mowers sure do seems to have a lot of traction off the line). Anyway, here's my finished product. I'm a lot happier with it because has a lot less of that homemade look. h ttp://photos.yahoo.com/bc/benleemd/vwp?.dir=/datsunZ&.src=ph&.dnm=T5slave.jpg&.view=t&.done=http%3a//photos.yahoo.com/bc/benleemd/lst%3f%26.dir=/datsunZ%26.src=ph%26.view=t Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted November 13, 2002 Share Posted November 13, 2002 I used the T5 slave on my T56, because of the bleed screw. Both slaves have the same volume, and the T5 is just easier to bleed. Quote Link to comment Share on other sites More sharing options...
