Interior door panel/Handle question
The chrome trim is popped loose from the outer lip. It clips on a metal piece underneath that the strap retaining screw goes through. You then have to slowly work it down the strap so you can get the the retaining screw. It may very well break due to age though. Luckly, Nissan still has these. I bought two from http://www.Courtesyparts.com for about $22 each plus shipping.
From a prior post, "The pull strap including the chrome bits is available at Courtesy Parts in Tx. I have dealt with them quite often. Ask for David as he is the S30 guru. I believe I paid around $22 each for these straps. Part number is 80950-E4100 and labeled as a grip assy."
