280zss Posted March 26, 2009 Share Posted March 26, 2009 Hello all Well I've been lookin for a fuel pump all week. Local stores have an airtex for about 100 bucks ( which sucks I've heard) and the Bosch for 275 with lifetime warranty, but that is A LOT of money; Anyone used a good replacement pump for a 76 280z?? I called Black Dragon but they won't say who makes their repop pump. Its 190 bucks. Also, on a 76, I cant just replace the fuel pump relay?? It is in the EFI relay??? Do those go bad??? They are about 110 bucks at MSA. I also plan to get a new FPRegulator. Any reccs?? If my fuel system doesn't hold pressure after shutdown (drops to 0 psi in about 10 seconds) and my pump gets louder the longer I've driven it (its usually quiet every time i start it and its cold) does that indicate pump and FPReg? Thanks Oh I'm cleaning all the electrical connections/grounds today to try to fix rich problem. I've read the EFI bible and understand it now. Quote Link to comment Share on other sites More sharing options...
ezzzzzzz Posted March 27, 2009 Share Posted March 27, 2009 Have you considered that you may have a leaking injector? That could account for the rapid pressure drop and rich condition too. Pulling the plugs shortly after shutoff might indicate a possible culprit (very wet plug). Does the oil reek of gas? I can't speak of the pumps or relays because I'm still running SU's. Quote Link to comment Share on other sites More sharing options...
280zss Posted March 27, 2009 Author Share Posted March 27, 2009 Thanks for the reply. Yes, I have considered the injectors. I did the screwdriver/ear test on them and they all sound even. I pulled all the plugs and they are all equally carbon fouled black. They smell like gasoline. Main reason I suspect fuel pump is the loud whining it begins to emit when car has began to warm up, a telltale sign of soon failure (so I've been told). Its not as loud when first started. Any specific test for injectors using ohmeter I can use?? Thanks again. Also, I have considered buying the Delphi fuel pump. Airtex seems to suck and fail, and the Bosch is real expensive. Any experience with these pumps anyone? I know they supply GM with lots of parts. Was def running rich, a little better now that I've cleaned all connections and adjusted TPS for proper contact. I plan to put new NGKs in there if I can't clean mine off, they only have about 300 miles on them (NGK also) Quote Link to comment Share on other sites More sharing options...
