Jwink25 Posted January 26, 2003 Share Posted January 26, 2003 I have a L28ET that is out of an automatic car. I am putting a 5 speed behind it. Can I use a 240 or 260 flywheel behind it? And can I use the clutch and pressure plate from a 240 or 260 Z as well? Thanks. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 26, 2003 Share Posted January 26, 2003 I am not that familiar with 240 Z's or L24 motors. I am assuming that is what you have since your credits suggest this. Your 5 speed tranny has to be a 1977 or later. The biggest problem is that your flywheel bearing collar must match web page the style of the flywheel. The ideal solution is to obtain a flywheel,pressure plate,clutch,throw out bearing,slave cylinder and clutch fork from a 1975-83 motor with a 2+2 and Turbo Zx being the most desirable using a larger 780 pound presure plate and a wider clutch contact area. The 2+2/ZXT and the coupe clutch are not interchangeable because the pressure plate dowel holes will not match.Remove the 1/4 inch metal spacer between the automatic drive plate and crank when adding the flywheel. I imagine you could use a 240 or 260 clutch "if" you find the right flywheel and throw out bearing. Pull a flywheel,pressure plate,slave cylinder clutch fork and throw out bearing out of a 2+2 75 up L28 and you got about the closest thing to a full competition clutch available Quote Link to comment Share on other sites More sharing options...
Jwink25 Posted January 26, 2003 Author Share Posted January 26, 2003 Ok guys, thanks for the info. I guess I'll start roaming the slavage yards. Unless someone here has got what I need. Quote Link to comment Share on other sites More sharing options...
