NMCA #1 Transmission
I just installed a transmission in a Z for a friend of mine. But I'm not sure of its' origin.
The original was a standard Z five speed with L5 stamped in the side of it. This one has
NMCA#1 cast into the bell housing and the gear housing, the bell housing was also a little thicker at the bottom making the two 12mm bolt/nuts to short and it has a sleeve on the back of it to protect the driveshaft which the other did not have. Also it has L4 cast in the bell housing, but it is a five speed. Any help would be appreciated.
God Bless,
Rick,
  • 6 years later...
I also have this same transmission that I'm rebuilding. I ordered bearings and they match for a fs5w71c trans. I don't know which car or truck this is from but it seems like it is either
84-88 200sx
83-87 300zx
84-86 720 truck
My trans has all brass syncros, 1st and 2nd syncro rings being larger than 3rd and 4th. This also has one 5th ring that is even smaller yet.
