My Z is one solid color again!
tkach
its finally all one color!
Ill post some more pics of the motor as soon as I can take them.
picture.php?albumid=37&pictureid=202
picture.php?albumid=37&pictureid=203
picture.php?albumid=37&pictureid=204
here is the rundown on the car
Motor
Small Block Chevy 5.7 350Cu In Stock Truck bottom end
Hei Distributor with Mallory Internals
Accel 300+ Spark Plug Wires
Accel Header Shorty Plugs
Mallory Hi Fire Ignition box
Block Hugger Headers
2 ¼ In Exhaust to Flowmaster Y pipe to a 2 ½ Stainless MagnaFlow Muffler
Holly 4510 750 Cfm Carburetor
Edlebrock Performer RPM Aluminum Intake Manifold And Matched Camshaft
World Sportsmen Heads
2.02intake and 1.6 exhaust Valves
1.6ratio Billet Aluminum Roller Rocker
hardened Crane Pushrods and guideplates.
64 CC combustion Chambers
200 runners
Optima Red Top Battery
Hydraulic lifters
3/8 In Fuel Line
Duel Feed from tank to pump All lines from tank to pump and from pump to engine bay are AN
Holly Red Electric Fuel Pump
Jegs An Billet Aluminum Fuel Filter
Black Mountain Precision Billet aluminum underdrive pulleys with 1 inch cog belt.
All New accessory Starter Alternator Water pump
Fabricated aluminum overflow catch can
JTR Aluminum Radiator Mounting Brackets
Billet Aluminum Motor Mounts
Correct Adapters that allow utilization of stock Datsun Gauges.
Oil pressure warning sensor that detects oil pressure/low level conditions and proceeds to shut off fuel pump
Drive Line
Turbo 400 trans Fresh Rebuild 1 ton chevy end
Lokar Dipstick
B&M Z gate Shifter
Cannon Engineering Driveshaft Custom Slip and spline design with solid Chevy 1 ton ends
R200 Rear end with chevy 1 ton end adapter 3.54 gears
JTR Speedometer Cable Adapter
Polyurethane Differential Bushings.
Brakes And Suspension
Toyota 4runner Four Piston Calipers
Brembo Rotors
Polyurethane Steering coupler
Polyurethane Sway bar kit
Polyurethane Tie Rod Kit
Motorsports Auto Rear Strut Tower Brace
Body
ISMA spoiler
Front Air Damn Molded into the body
Custom Shaved marker lights
Smoked Headlight Covers
Custom Vented Hood
Custom Shaved wiper grill
Smoked Signal lights
Vortex Generators
Lexan Rear window.
Interior
New Dash
New Carpet
B&M Z Gate Shifter
