240z turbo fuel injectors???
J240ZTurbo
Hi, I m putting a 240z turbo together with L28et engine . I will be running a regular 76 ecu and wire harness with a stand alone dist from a NA 280zx and a 76 gas tank. My Turbo injectiors are not good so here comes the question what injectors can I used for this engine running with what I got????
I ran a L24e maxima for 50,000 miles on stock 280zx turbo boost using the stock injectors.
I'm sure it was near leaning out but the car is 2.4 liters versus 2.8.
Since all the L24e and L28e run the same size injectors, I ran the L28 ecu in the hopes it ran slightly longer pulse width because of the larger engine but there might not be any difference.
I was also running cheap aftermarket python injectors (white color) so it is possible they flow more than they should because they are cheap.
