Guest BadKarmaCreepin Posted June 25, 2001 Share Posted June 25, 2001 HERE'S ANOTHER ONE I FOUND ON EBAY>> "http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=592703595&r=0&t=0" Thanks Dan Quote Link to comment Share on other sites More sharing options...
Guest BadKarmaCreepin Posted June 25, 2001 Share Posted June 25, 2001 ONE MORE>>> ...a rebuilt 350 engine, it has 8.5-1 compression and can run on 87 octane gas, it uses dished pistons and high flowing GM 1.94 valve heads (with new guides, valves, and Z springs), the block is a 010 high nickel 4 bolt main block bored .030 over, it has a Comp 262H extreme energy cam (this motor has got alot of low end and midrange torque), double roller timing chain, high volume speed pro oil pump, Melling hardened oil pump driveshaft, 10-10 crank, it also has a brand new Edelbrock performer intake and a rebuilt quadrajet carb, it has a brand new set of chrome valve covers with breathers and a PCV valve, it comes with an 8" harmonic balancer and 168 tooth flywheel (this motor is completely assembled). The motor has been run to break in the cam and rings, it runs excellent with 80 pounds oil pressure cold idle and 60 pounds hot idle, the compression is 150 on all 8 cylinders. Also comes with 8 autolite spark plugs and a fuel pump. This motor is rebuilt with top names like Fel-pro, Speed pro, Clevite, Melling, Comp, Elgin... Just needs your distributor and water pump to run... Dan Quote Link to comment Share on other sites More sharing options...
DavyZ Posted June 25, 2001 Share Posted June 25, 2001 This sounds like a good mild street motor that would be very good for a first-time conversion project. Over time, you can always start upgrading this motor. If the price is right, this might be a good buy. Davy Quote Link to comment Share on other sites More sharing options...
