can i re-adjust?
Guest lelandstrott
Guest lelandstrott
I am using the EMI camber plates. It doesn't seem to me that taking out camber would affect the alignment of the front tires. Is that correct? I"m currently at 2.2 degrees negative in the rear which is a bit much for street tires. Fronts are about the same. I was planning on going for about 1 degree negative both front and rear.
When I decide to go racing again, I can re-adjust, but the car is street-driven now ?
