V-Blok sound deadener?
BLKMGK
Came across mention of something called V-BLOK in one of my car mags. This stuff is a spray on sound deadener that apparently has SOME rust inhibitors and may insulate from heat a bit as well. I don't know about you guys but my Z with a 6 sounds a little tinny and I can't help but wonder how a V8 will make it rattle :-)
Check this stuff out - VB-1. 1 gallon of VB-1 w/rust inhibitors is about $70 in sprayable form. $60 for the gun. With Ceramic heat barrier (R24) it's $124. The "exterior" grade in black is about $78.
http://www.cascadeaudio.com/
Anyone else found a good sound dampner? Anyone using the DynaMat spray? The pads? What are you dooing, if anything, to turn down the noise level a bit?
