Arif Posted December 30, 2000 Share Posted December 30, 2000 The block off plate on the front of my L28T head has a broken bolt. The plate won't seal with only 2 of the 3 bolts in the head. Because of the location (in the front of the engine) I can't drill it out without pulling the radiator to get at it. Is there a type of sealant that is resistant to engine heat and oil that I can use? Any ideas are welcomed. ------------------ http://communities.msn.com/TurboZ Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 30, 2000 Share Posted December 30, 2000 JB weld will work, Disassemble parts, clean them, mix and apply as directed, let cure and hope you dont have to take apart again. It will help if you use a rough grit sand paper on the mating surfaces also. JB weld is a two part epoxy available at most auto parts stores. Mark Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 31, 2000 Share Posted December 31, 2000 a right-angle adaptor on a drill motor might fit in that tight space (???)allowing you to remove the bolt...or JB Weld...how good a repair do you want to make??? Quote Link to comment Share on other sites More sharing options...
Arif Posted December 31, 2000 Author Share Posted December 31, 2000 Thanks guys. I did buy a dremmel with the right angle adapter yesterday. I drilled too much material (the bolt and the hole). My next step will be to buy a tap and dye set to regroove the hole larger than it was originally. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted December 31, 2000 Share Posted December 31, 2000 Hey Arif, JB weld works for threads that won,t be highly stressed, of course if you can tap new threads this would be the best way to go or you might try a heilcoil thread insert. Mark Quote Link to comment Share on other sites More sharing options...
Arif Posted December 31, 2000 Author Share Posted December 31, 2000 Thanks Mark, Now if I can find a new gasket for the front cover on the head. I don't know why nissan even put a plate there. It serves no purpose but to look at the chain (kinda like a peep hole) Quote Link to comment Share on other sites More sharing options...
