evan1242 Posted May 17, 2009 Share Posted May 17, 2009 (edited) hey guys, im new to this web site, but not Z cars. i have a 1983 280 ZX Turbo that is intercooled and is running 10 psi of boost using a MBC. i have a barbed fuel rail from lone wolf performance and i want to know if there is a way i can make it work for a set of O-Ring supra injectors? (440cc) thanks Edited May 17, 2009 by evan1242 needed to make barbered to barbed Quote Link to comment Share on other sites More sharing options...
garvice Posted May 21, 2009 Share Posted May 21, 2009 Use a bit of 8mm fuel hose and clamps. My injectors are o-ring type and I have about 50mm of fuel hose on each injector. Clamp on the barb end and clamp on the injector end. I kept my o-rings in as I had a little bit of leaking without them. Quote Link to comment Share on other sites More sharing options...
evan1242 Posted May 22, 2009 Author Share Posted May 22, 2009 thanks man, that sounds great Quote Link to comment Share on other sites More sharing options...
garvice Posted May 22, 2009 Share Posted May 22, 2009 I also used some heat shrink over the clamps so that you can't see my clamps. I can take a photo sometime if your interested. Now that I think about it, I think I started with 8mm, but it was too hard to get over the injectors. I think I ended up using 9mm hose. Quote Link to comment Share on other sites More sharing options...
evan1242 Posted May 23, 2009 Author Share Posted May 23, 2009 that sounds good, and yes, a picture would be awesome thanks again Quote Link to comment Share on other sites More sharing options...
garvice Posted May 23, 2009 Share Posted May 23, 2009 Quote Link to comment Share on other sites More sharing options...
evan1242 Posted May 24, 2009 Author Share Posted May 24, 2009 that looks really good man, thanks for the help! Quote Link to comment Share on other sites More sharing options...
