Challenger Posted May 19, 2009 Share Posted May 19, 2009 Hey, Im in the process of organizing the engine bay on my 280zxt and there are a couple small "things" attached to the side of the AFM. There are several vacume lines that go into them along with a couple plugs. The Diaphram on them says "VCM". Does that mean vacume control module? What does it do? Thanks Quote Link to comment Share on other sites More sharing options...
evan1242 Posted May 19, 2009 Share Posted May 19, 2009 it does exactly what it says. there should only be three vacuum lines coming off of the VCM. the either go to the boot between the AFM, and the turbo, or to the little steel rails along the side of the intake manifold. (and i think one of them is supposed to have a little check valve thing spliced into the vacuum line.) Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted May 19, 2009 Share Posted May 19, 2009 One controls the idle and one controls the egr valve. Quote Link to comment Share on other sites More sharing options...
Challenger Posted May 19, 2009 Author Share Posted May 19, 2009 Quote it does exactly what it says. Well it said VCM so I assumed it didnt VCMificate. Alright, from what Ive found its ok to remove it, just make sure all the new vacume leaks are plugged. Should any of the wires coming off of it be addressed or does just leaving them there to tangle work ok? Thanks Quote Link to comment Share on other sites More sharing options...
