Guest Anonymous Posted May 16, 2001 Share Posted May 16, 2001 Hey guys, The other day as I was riding to work in my '00 Saturn "work car" w/the A/C blowing strong and cold I was wondering if the entire evaporator/blower assembly from a late model car like that could be swapped into a "Z". Yea, I know it would take a bit of fabbing, but it probably would pay dividends when the weather turns hot and humid. I read about blower upgrades and that is definitely an option but I like the idea of having a complete setup which is a little less antiquated. Also could use the modern switch panel which I feel could fit in the stock console. I read something about 'RX7 blowers working. I owned a first and second gen. car and I think the first gen. setup is a pretty good candidate but the second gen. cars were known to have logicon problems so I would probably bypass that option.I am going to look into this a bit more and will post if I come up with anything of interest. I would welcome any input,etc. Terry Walton '75 280(returned from the grave after a year of hiding the receipts from the wife) Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 16, 2001 Share Posted May 16, 2001 I used a Hot Rod system from Vintage Air. It fit under the dash great with a slight mod. It's for large Hot Rods so it should cool fine in a Z. As soon as I get the car and air going I'll let you know how it worked. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 16, 2001 Share Posted May 16, 2001 Someone mentioned a Civic fan motor as being a bolt in, can't recall the year civic though. Its probably in the archives.. As Mike said, Vintage air makes all sorts of different packages that include heat and air. If I would have had the cash when I had my dash out I would have seriously looked into it. Looked like a matter of mounting the unit, hooking up the vent/defrost hoses and the heater/ac hoses, the controls (depending on the model Vintage air used) are on a small little panel that could be fit into the stock dash with a little cleaver engineering. Or just use the panel in another spot and enjoy the area taken up by heat controls in the stock dash for additional gauges/switches. Regards, Lone [ May 16, 2001: Message edited by: lonehdrider ] Quote Link to comment Share on other sites More sharing options...
