NewZMan Posted June 9, 2009 Share Posted June 9, 2009 I have a 83 280ZX Turbo, totally stock from the bottom up. I am running MsNS extra on MS1 v3 PCB. I just upgraded to an EDIS 6 and got the car idling. The problem is I get an intermittent Timing Light signal and when throttle is applied the car will stumble and die. The idle is perfect though. I have searched and searched this site, but couldn't find anything close so I'm begging for some guidance. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted June 10, 2009 Share Posted June 10, 2009 Is the EDIS stuck at a single advance number, or does its advance follow the readings in MegaTune? Quote Link to comment Share on other sites More sharing options...
NewZMan Posted June 11, 2009 Author Share Posted June 11, 2009 It seems to be advancing. I compared what was showing on MegaTune with a timing light and they appear to match. The idle is solid and strong, and I'm beginning to think its fuel related. When the gas is added it stumbles and sometimes dies and appears to be running really rich. Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted June 11, 2009 Share Posted June 11, 2009 Might be too much acceleration enrichment then. Try disabling it and get the VE table dialed in first. Quote Link to comment Share on other sites More sharing options...
NewZMan Posted June 12, 2009 Author Share Posted June 12, 2009 Thanks I'll try that in the morning and see what happens. Quote Link to comment Share on other sites More sharing options...
NewZMan Posted June 21, 2009 Author Share Posted June 21, 2009 It was a tuning issue. I've got it dialed in much better, with a nice smooth idle and smooth throttle response at idle. I changed out my wiring to shielded cable and things seem to be much better as far a noise goes. No resets. Next will be a test run and logging. Wish me luck! Quote Link to comment Share on other sites More sharing options...
