Is this a problem with my duty cycle?
ArizonaZ
I just finished installing my megasquirt on my 260Z with the E88 head. I have gotten it to run and idle quite well and it will rev nicely. The problem im having is that it wont sustain any RPM above idle. If I try to give it a constant throttle position the duty cycle will decrease and it will bog down and die. Here is a datalog of when it happens, its about 3/4 of the way through. Is this something I can fix in megatune or is it my injectors?
Data Log.zip
I noticed one reset, that's often a noise issue and needs to be fixed.
Here's what happened when the duty cycle dropped. At one point you had the RPM dip below 300, which put the MS in cranking mode. When the RPM came back up, the afterstart enrichment kicked in for a while, and that's something that adds fuel but then tapers off quickly.
